Fluctuating (low) voltage: what does it mean?
With the A/C on yesterday, the V was dropping below 12, which scared me. I ended up buying a new alternator and installed it 2 hours before picking my sister up from the train station.
FWIW,at idle, fully loaded, the new alternator was only reading in the mid to high 12s. I checked a buddy who has the same exact car with a recently installed reman'd alternator and his was similar.
>1,000 RPM and on the highway is where the MAJOR difference was. Before, it would fluctuate from low to mid 13s. After the install it stayed planted at 13.9V +/- .1V at anything >1,000 RPM. I feel a lot more confident that the Subie won't leave her stranded any time soon now. : )
I got her to 206,500 miles. Hopefully, she'll taker her to 300kmiand beyond!
If you absolutely need more voltage at idle or very slow speeds, you can get an overdrive pulley for the alternator.
It's simply a slightly smaller pulley.
Rebuild shops will have hundred of odd ones lying around.
That's one of the coolest things to see in a newer vehicle.
On hot sunny days when the AC is roaring our GM products will wait a minute or so at a light and then very slowly ramp the idle up until the voltage comes up to near 14.
