Those look good, but it’s Amazon and OP doesn’t need that many or to pay $15 or whatever for them.It probably takes a speed nut that looks more like this:
Loading…
www.amazon.com
(not necessary that exact one though)
You can probably find these in a box AUTO parts store like Autozone, Advance, OReily in the body section on a spinning tree with push pins and the like.
Nice job. Execute and take in the advice tha you get here. Read it all. Consider it all. Make informed decisions.View attachment 133360
And a song by Hot Chocolate. Something about "I believe in miracles."
Oh.. oh..
View attachment 133361 View attachment 133362 View attachment 133363
@JHZR2 was right (again) that was pretty really simple, eh.
Now let's go check out filter cutters and get some gas in the 3.0 and just have a Happy New Year.
I feel some 100% random pics coming.
The other one was too wide...
Happy New Year.
User name checks out.What's wrong with the zip ties? I'm rocking zip ties on quite a few things on my vehicles. Trans cooler, ps cooler, coolant bottle. I even have ratchet straps holding down the trans in my truck!
You're not doing it right unless you cut an access hole in the floor to get to the trans.User name checks out.
JUST KIDDING!
Seriously, I'll white trash (sure it's a verb!) with the best of them and I'm happy to use quality T&B zip ties to hold wiring harnesses, vac lines, etc.....but for hard parts and esp those which can have some weight to them (is washer fluid also roughly 8# per gal like water?) and a live load.....well, zip ties as a permanent fix exceed even my white trash quotient-- so that's cause for concern![]()
Looking for it now, dude cut an access hole in the floor of an Avalanche I think it was. SMA or something. Didnt want to go forward fixing it..
Another question. What kind of coolant did the 2004 Taurus with the Vulcan 3.0L V6 come with? Was it Ford DexOrange or green?
Yup, that's correct, it would be the yellow G05 stuff.TTBOMK Ford went HOAT circa '03, so G05 "Gold" or similar. I don't think they went OAT DexCool until ~2011
Cascade! I like it. I thought I didn't have the "updated style" of tank I have to check that out.Yup, that's correct, it would be the yellow G05 stuff.
Also, some cascade, water, and some vigorous shaking should clean that bottle up.
Cant say I’ve ever seen it in store. AZ stocks it, as does Napa.Walmart has the correct Zerex G05 on their website if you don't want to darken the door of the Ford dealer:
Robot or human?
www.walmart.com
Back when we had our Expedition (so going back quite a few years now), they stocked it here locally. Sounds like there are a couple of options that stock it though, so that's good to hear.Cant say I’ve ever seen it in store. AZ stocks it, as does Napa.
I also bought these items at Lowes and/or Ace hardware (which seem to stock this type of thing around me better than Home Depot).Those look good, but it’s Amazon and OP doesn’t need that many or to pay $15 or whatever for them.
Ditto for dealer speed nuts that are probably $3 each!
But these items are the right idea.
Looks like OP went to Home Depot based upon the bags the fasteners came in. Nothing wrong with those especially for the application at hand. A million ways to skin this cat, A-R behaviors aside.
I just read from the product description that the G-05 is an HOAT. {snip}
Yah.. you did.. mentioned "Ford went HOAT." Now, this may sound stupid, but, I read that and didn't put two and two together until talking with someone advising me on this matter (said "Don't mix coolant" and wasn't impressed with me stating use of Universal) and then saw when I looked up G-05 that it mentioned HOAT. No easy way to explain that except that it didn't register. Now it does.Ya don't say?? I feel like I specifically mentioned that in Post #48. What did someone say about OP not reading......??
Apparently it holds 11.6 quarts so basicly 3 gallons. So I've replaced approximately 1/3 of it. Think any damage occurred?
