My car has a pretty good size crack in the condenser, so I have been gathering supplies to replace it.
Im about done with that stage. Next is to acquire the parts needed.
Im also definitely getting a Accumulator. Its not technically needed with a condenser change out, however it is of a fail design in a fail spot and likes to rust out. They are not expensive either, so I will just throw one in.
My question is, should I replace the compressor too? The reason I ask is because it rattles sometimes. I have not yet figured out what causes it or why it only does it sometimes. I went over the clutch last year to make sure it was tight and in good condition. I did find the gap just a smidge wide, so I pulled the face off and sanded down the spacer a bit to tighten it up.
It still does it. Only when the clutch is pulled in, which is what worries me about it. I would hate to have to take it back apart to put a compressor in it. I think I am going to do it, but I wanted some opinions and maybe someone has something that I might've overlooked.
