Hi everyone,
Here is the UOA on my first oil change. The oil change was done at 9600 miles. I am worried about the high Al levels. I know that the wear metals will be higher during break-in, even my second oil change and UOA will probably still show a bit higher levels until they stabilize. Should I just not worry too much about the Al?
Thanks!
Fe: 65
Cr: 4
Ni: <1
Al: 150
Pb: <1
Cu: 48
Sn: <1
Ag: <1
Ti: <1
Si: 29
B: 8
Na: 29
K: 543
Mo: 6
P: 512
Zn: 738
Ca: 1216
Ba: <10
Mg: 12
Fuel% Vol: <1.0
Water% Vol: <1.0
Vis. (cst) @ 100C: 11.0
SAE grade: 30
Glycol test: negative
TBN: 2.55
