Firestone ph500 filter
As a general rule the <3" dia. (smaller) Champs like ST/STP are not ecore. Larger diameter (>3" dia.) are ecore with just a couple/few exceptions. The Fram Xref show the PH 500 to < 3", so perhaps not an ecore. You could likely confirm by checking the equivalent make/model application ST at Wally or STP at AZ, that would give you a good indication without going to Firestone.
Originally Posted By: stp44
Is the Firestone Ph 500 a ecore filter. I would think that it is because it's made by Champ Labs but I have not seen one.
I believe it is (99% sure).
