Finished all the machining, made a few changes from testing over the weekend. Had to move the cutter to the center, cut fine being off center but could only spin the filter counter clockwise or it would come out if spun clockwise. Also had to raise the wheel it self up a little bit, also machined some drain channels and added a drain plug
Just need to add silicon to the outer covers where they meet the main plate to eliminate leakage. Here it is, I had a lot of fun creating it. With all the extra parts I sawed up in case I scrapped any parts wound up having enough to assemble two more. You'll see the design changes in the pictures, final design is on the right.
