On a cold start my late model GM engine sees 60psi max even at low rpms. It stays there until the oil warms up enough to drop the psi down to 25psi at low rpms and will climb to 40psi at higher rpms. Is it safe to say, 60psi is the bypass level, cause it never gets higher than that no matter the rpms when the engine is cold. Am I also safe to say, 40psi when the oil is hot is always in the non bypass. If this is so, then during my longer drain intervals, I will keep an eye on my max hot oil psi. If it starts to creep to the 60psi max, then I will have to change the oil filter cause it will be clogged and causeing bypass. If not, then will go the full 10,000 miles extended oil change interval without a oil filter change. I'm running 15w40 Royal Purple and the Delco OEM PF44 filter.
Leo
Leo
