- Joined
- Aug 7, 2020
- Messages
- 5,167
Thank you. I'll give 'em a call and try to make an appointment after Xmas.Ask for John Bridgewater.
I think a scanner is a standard tool everyone should have. A couple that come to mind is the Autel AP200, does all manufacturer specific error codes in addition to standard OBD error codes. Thinkcar Pro is also good, used to be more than Autel but now cheaper. At the very least, you should get one that does standard OBDII error codes.There is a subtle roughness at low engine speeds that seems to diminish at higher revs, over about 2200rpm. However, I think the roughness may be masked by the engine rpm. I don't have an OBD scanner, however, I had a trusted shop go through the car, looking for codes and examining systems for problems. No codes turned up, all of the systems they checked were fine. nonetheless, the roughness persists.
I'm planning to put in a new set of plugs, maybe that would help, but I'm not doing the plug change just for this roughness ... it's about time to change 'em regardless. However, I do not want to just throw parts at the problem. I'd like to find someone who can take the time to drive the car, who has some sensitivity to the way an engine should run and sound, and who has the experience, the tools, and the temperament to delve into the issue.
It could be a situation where multiple mechanics say "I don't see, hear, or feel anything wrong" too.Also, a "subtle roughness" is going to be difficult to convey
Followed by...It could be a situation where multiple mechanics say "I don't see, hear, or feel anything wrong" too.
If your spark plugs and wires are due to be replaced, you're not throwing parts at the problem (per se) to continue to do the maintenance it needs anyway. I see no reason to wait on that and it might just solve the problem too.
I seem to recall saying just that ... Great Minds ...
No, it's not a bad tank of gas. It's been going on for close to a year. During that time there have been two tanks with Redline SI-1 fuel system cleaner, a check of all belts and pulleys, a scan for any codes, tire rotation, and road force balance, and I cleaned out my coin tray. All of this was part of regular maintenance and preparation for a long road trip, not specifically for the problem.How long has it been happening? Could it be as simple as a bad tank of gas?
Damon Russell would be the person to ask for. Damon is the shop manager. Known him longer than I have known John and is an absolutely fantastic techAsk for John Bridgewater.
rough transition is usually a delightfully tiny vacuum hose or EGR leak. Which a pro will track inside 45 minutes.To do the basics before going to a shop or not to and let them have it untouched. Me, i`d do it along with written details.
BUT.. did you DO it?I seem to recall saying just that ... Great Minds ...
If the car in question is the 2011 Camry 4cyl - I had one in with rough idle (smooth above idle) and it was a bad motor mount.....check there 1stThere is a subtle roughness at low engine speeds that seems to diminish at higher revs, over about 2200rpm. However, I think the roughness may be masked by the engine rpm. I don't have an OBD scanner, however, I had a trusted shop go through the car, looking for codes and examining systems for problems. No codes turned up, all of the systems they checked were fine. nonetheless, the roughness persists.
Please send me your money cuz it sounds like you are about to throw it away over nothingThere is a subtle roughness at low engine speeds that seems to diminish at higher revs, over about 2200rpm. However, I think the roughness may be masked by the engine rpm. I don't have an OBD scanner, however, I had a trusted shop go through the car, looking for codes and examining systems for problems. No codes turned up, all of the systems they checked were fine. nonetheless, the roughness persists.
Tell me, please, what you know about the car and the situation that causes you to feel that way? I'm also curious about the expertise that allows you to make such a pronouncement from a couple of internet posts. What have I, or anyone for that matter, said that affords you such insight.Please send me your money cuz it sounds like you are about to throw it away over nothing
It's interesting that you mention motor mounts. I too had some thoughts along that line and actually made a few inquiries about the possibility. Didn't get any meaningful response. Thanks for reminding me.If the car in question is the 2011 Camry 4cyl - I had one in with rough idle (smooth above idle) and it was a bad motor mount.....check there 1st
Ordered the plugs a couple of days ago, will put 'em in when I do the next oil change, maybe before depending on the timing.BUT.. did you DO it?
A shop should not just try to pull codes, if there are no codes then next step is a scanner with realtime data while running. I suppose that's the next "step" in mandatory equipment that any shop necessarily has so I wonder that you aren't mentioning anything further diagnostic than code pulling... could just be poor communication from the shop.
