Finally found Mc 910s filters
Illinois
I usually get the 910s at WM, but haven't seen them for a few months. They had three so I bought two.
In times like this with supply shortages, hoarding becomes part of the problem too, which helps keep shelves empty. Then when someone sees a bunch again, they buy them all, so hoarding creates more hoarding. Some products get buy limits set, but that will never happen with oil or filters at Walmart.
i like to keep the next oil change parts so when the impulse hits I can change the oil with out having to go to the store.
I would agree to that. Thanks.
You can always use fram orange can . It’s what what usually get if motorcraft not available . Too lazy to drive to another Walmart
Thanks for the tip, however I won't use the OCOD. I can order the MC 910s from my local O'Reilly store where I get my MC 2017B cartridge filters for my 2007 Fusion. Only a buck fifty more.
FL400s is about 20mm longer than FL910s but otherwise identical. If you have space for a longer filter, the FL400s model is found to be generally more available.
I haven't seen the 400s either at WM in several months.
