Finally doing a drain and fill to focus
IL.
People with focus's. Should I do the fill with Mobil 1? I moved closer to work so I'll be doing lots of short trips now. The car has 75,000 on it. 2010. Runs perfect
Automatic? Focus's transmission's have no known issue so any Merc V equivalent will work. Put M1 ATF in there you many never need to change it again.
A 2010 would require Mercon LV. Mechanically, I don't believe there is anything different between the 4f27-E in your 2010 than a 2001 that also has the 4f27-E transmission. Install a transmission cooler on it if it doesn't already have one.
