Switch nipple on block back to standard 3\4=16 and run PL30001. The nipple is about 12 bucks from dodge. The metric filters are smaller and cost more. I ran this filter when I had a metric thread.
Part Number: 51592
UPC Number: 765809515925
Principal Application: Cummins, Komatsu, Onan Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.214
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 18-20
Burst Pressure-PSI: 250
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
15614 2.834 2.462 0.255
