Box says wix but the minder is labeled made byDonaldson.
It’s pretty much self explanatory.
Just drilled an 11/16 hole on the clean side. Sanded the drilled area lightly with fine sand paper. Stuck the rubber grommet in and seated the minder stem into the grommet. Vacuumed the box and all out and stuck a wix air filter back in.
Put the air box back on and tightened the hose clamp.
I’ll see how long it goes till the minder indicates time to change the filter.
