filter for 01 bombardier ds-650
New York
anyone know where i can get a filter online for this quad other than k&n? I hate to pay $15 ea plus shipping for this tiny little thing. The local dealer wants $12 each! The bombardier part # is P711256186, im having trouble crossing this everywhere. Any help is appreciated.
Pottstown, PA
What's the K&N number? Or do they feature K&N as the OEM manufacturer and that's the number they use? Is this a spin-on or a cartridge? This has a 653cc Rotax engine. Does it look like this?
SmotalChaos
New York
Nope, cartridge filter. I bought one replacement at a dealer around here for the $12 I mentioned above. They had two different filters listed for this year and model, one a little longer than the other. I knew it was the shorter one because I had already pulled the old one out. The # that I listed above is off of the box, which is "bombardier genuine parts". I will have to pull the filter out of the quad again to see who it is made by, but I doubt it says so. I found out on one site that bombardier switched to a longer filter halfway through '01, so that was why the dealer listed two different ones. Now, K&N's website lists the KN-152 for the '01 model and up, but the KN-151, which is a little shorter, for the '00 model. I am guessing the replacement for my bike is the 151, but again, Ill have to pull the filter off to measure it and be sure. All I have right now is the # off the replacement filter box...
Pottstown, PA
KN-151 Product Specifications Product Style: Oil Filters Height: 2.028 in (52 mm) Outside Diameter: 2.205 in (56 mm) PSI Relief Valve: 24.07 Anti Drain Back Valve: No Style: Cartridge Weight: 0.2 lb (0.1 kg) Product Box Length: 2.5 in (64 mm) Product Box Width: 2.5 in (64 mm) Product Box Height: 2.25 in (57 mm) KN-152 Product Specifications Product Style: Oil Filters Height: 2.953 in (75 mm) Outside Diameter: 2.205 in (56 mm) Anti Drain Back Valve: No Style: Cartridge Weight: 0.1 lb (0 kg) Product Box Length: 2.75 in (70 mm) Product Box Width: 2.75 in (70 mm) Product Box Height: 3.13 in (79 mm) I can't get anywhere either. Donaldson has a filter that fits the dimensions, but no bypass valve that these allegedly have. P555400
SmotalChaos
New York
I found the filter @ parkeryamaha.com. The part # was superseded with a new one, 420256186. Looks like it's made by champion. $10.75 ea there. Getting warmer...
