what determines film strength? ![[I dont know]](/forums/graemlins/dunno.gif)
quote:Exactly how long would the barrier lube last if that is all that you relied on? Just wondering. For instance if you had a weak base stock with a low film strenght but a lot of barrier lube additives?
Originally posted by BOBISTHEOILGUY: Now you rely on barrier lube properties for wear protection.
quote:I think Geo was referring to Bob labelling Terry as a Cubical Engineer... ...just clearing things up.
Hey Geo, It's quite apparent that you are new to these boards. I would hardly call Terry Dyson a Cubical Engineer . He's one of the most (if not THE MOST ) knowledgable lubricant analysts around.
quote:I'm really sorry this has stuck in your craw geo. First, lets get it straight. I never actually call some one a cubical engineer,(at least don't remember doing that) I may refer to their point of view as one. My interpretation of a cubical engineer is someone that is just that, a thinker, with lots of analysis and bench tests but with very little real application real world experience in the trenches. There are many who have and are, but also many that are not more than book smart with some excellent ideas. Second, I have never considered nor classified Terry as one as he and I know the definition. Now I might say he's thinking like one at one point or another. THIS IS'NT BAD! But he and I both know that our backgrounds would not permit us to be that way, or at least not for long. What is ment by all of this is, YOU CAN'T THINK OUT OF THE BOX. You're stuck on scientific papers and data that FAILS miserably at really SEEING the WHOLE picture when APPLIED to TRUE REAL WORLD APPLICATIONS. This is thinking like a cubical engineer. Someone that hasn't ever gotten down and dirty up close with engines, designs, repairs, experimenting(not on a bench) and checking out the end results. Was on a shrimp boat yesterday, looking at the rear seal on a detroit two stroke, also, at toyota being showed how some head gaskets actually have rubber gastet rings around the oil drainback ports in the head gasket and how the neutra had made a difference in slowing up a head leak on a seina, As well as discussing with a truck lube center how the grease applications to the drive lines compared to others and how someone came in and did one of those scientific tests with a dab of grease and a hammer.
Originally posted by geo: Bob labels scientists and engineers with professional experience as "cubical engineers", his pejorative. He fails to understand and appreciate the scientific method, analytical/comparative analysis, etc. Watch out for his opinions.![]()
quote:Thanks Oz. There is some history here that many may have not picked up from other threads. Bob labels scientists and engineers with professional experience as "cubical engineers", his pejorative. He fails to understand and appreciate the scientific method, analytical/comparative analysis, etc. Watch out for his opinions. Now, as Terry suggested, let's get back to the discussion.
Originally posted by The_Oz:quote:I think Geo was referring to Bob labelling Terry as a Cubical Engineer... ...just clearing things up.
Hey Geo, It's quite apparent that you are new to these boards. I would hardly call Terry Dyson a Cubical Engineer . He's one of the most (if not THE MOST ) knowledgable lubricant analysts around.Oz
quote:Ok, Now I have time to go a little bit further on this subject,OK, lets follow this through. Lets take a technical Publication Published by Texaco Inc volume 78. Definition of Viscosity... Viscosity, as a general concept, can be defined as the resistance of a liquid to flow or deformation. In common terms, the slower a material flows, the higher is its viscosity. Now here's where it gets interesting... IT IS THE VISCOSITY THAT DETERMINES THE ABILITY OF THE LUBRICANT TO MAINTAIN AN OIL FILM BETWEEN THE WORKING PARTS OF MACHINES, THE FILM THAT REDUCES FRICTION AND WEAR. Another term used is FILM STRENGTH How am I doing so far? Lets include a picture that might help demonstrate this even farther...
Film strength is relational to viscosity or flow
quote:Bob, Laminar flow is also important in aerospace. How does that apply to fluids? Supersonic flow, over a wing, is very fluid like. If you want more info on laminar flow look at aeronautics. My education on those was just a couple of college classes and basic pilot training. I suspect that may help. Is the inside of an engine close enough to a pipe for valid comparison? I don't know JJ Bula
Originally posted by BOBISTHEOILGUY: Syns can also flow in a turbulent fashion dissipating more heat while maintaining their desired film strength. NON syns flow in a laminar fashion holding heat Definition of lam·i·na (lm-n) n. pl. lam·i·nae (-n) or lam·i·nas A thin plate, sheet, or layer. The only thing I could find on the laminar theory was where it would apply through pipes. Viscosity is very important in flud flow throught pipes.
