Who makes reliable clutch master cyl 2013 Fiesta SE. The plastic push rod broke. Any remedy short of new unit.
Hope brake pedal push rod is not the plastic.
All I can say is that from Ford, this part is only sold with the complete clutch pedal assembly. It is actually pretty cheap at $154.37, well relatively cheap.
When I was replacing the blower motor on Jr's Mazda5 in November, I noticed a bit of seepage near the clutch pedal assembly, at the top where the clutch master cylinder comes through the firewall. I didn't have the motivation to do anything about it at the time - the blower motor just about did me in.
This morning the clutch pedal was very soft. I limped the car into the garage and up onto ramps, and bled a fair bit of air out of the slave cylinder on the transmission housing. The reservoir, which also serves the brakes, was quite low on fluid. I had to get the air out with a large...
I went with the FTE part from Rock Auto for the 2009 Mazda5 in our family. The part is likely very similar (or perhaps even the same).
So far, so good.
Edit: I can't find a clutch master cylinder for your car on the RA website.
Finally came in the mail today from Parts Geek. Sachs made in Germany and it has a metal rod! I just got the cylinder, not the entire assy.
Not too bad to work on. The poor guys in England have it pretty rough on their wrong side of the road Fiesta. A nightmare. Involves removing windshield wipers, The plastic plate below the windshield and more. Only thing I had trouble with was that I had to pull the line keepers out from the drivers side, almost a blind spot.
What's the Ford # for that Assy?
I got AE81-7519 with AFT-D 09 13 below it. If 09 13 is date it was made that is odd as car was built in May 13. Transmission built about a week before that. Speedo said about 20+ mile when I bought it in OCT 13 from Ford Dealer.
Sachs Cylinder came yesterday but is completely wrong.
The service part number is AE8Z7519A, the engineering number that should be on the part but is NOT the part number can be AE81-7519-AA, AE81-7519-AB, or AE81-7519-AC.
