Fiat 500 motor oil specs here (European version)
Pacnw
Info. from the owner's manual. 2.9 liters of oil.
I wonder what the US specs will be?
Oil changes every 30,000 km...not bad! Only thing is, with the ACEA C3 rating, it's a low SAPS oil. I was under the impression that the C3 category was mainly 5W-30?
Use to be owned by FIAT, now owned by Petronas. The Viscosity Oil firm in IL was sold by Pennzoil to Selenia in 2000.
At 2.9 quarts, sure better hope you don't get an oil burner.
Reqarding the lower volume, just check the oil level regularly like most people on this site do anyways, top off as necesary. Using less oil contributes to a cleaner environment, and in low performance daily driven vehicles probably isnt detrimental. However, going over 10k miles on an oil change bothers me, as I like to make vehicles last as long as possible
