Prepping for fluid flush, lines, pads for a 16 Challenger base.
I see a lot traffic about ABS flush procedure.
So I have a couple of questions!
1st - Why raise rear of car?
(This car has a far front mounted pump/valve assembly, and I suspect 'raise rear' is really a way to lower front assembly to increase odds no air gets into assembly, in case of underfill error.)
2nd - Not gonna' risk dealer, etc. - so how to flush ABS assembly?
I will also suspect Key On will cause cycling, and that fluid moved from assembly needs somewhere to go.
So maybe:
Ensure fresh fluid in lines approaching assembly (by normal flushing).
Open a bleeder.
Key On/ Off, maybe 5 times? (Moves assembly circuit fluid into line)
Normal bleeding on that corner and see some dirty come out?
Any help?
So maybe:
Open a bleeder.
Any help?
