LeakySeals
If Super Lube works good for both I will try it can I get it locally at the parts store?
Soak it in atf after use then exchange it next time you go to HF. Grease would be too thick IMO and would make assembly a bit harder than it should be.Doesn't seem to be anything wrong inside. Do I pack it with grease or just clean it out with carb cleaner and put it back together again?
Harbor Freight has it. The grey tube one is the one you want. I’m sure the parts places would have it too.If Super Lube works good for both I will try it can I get it locally at the parts store?
Thanks for the tip it's been working great! Just needed a little love.I started using that recently for finer tooth ratchets. For coarser tooth ratchets Super Lube works great.
