Ah, it is with both sadness and celebration that I share the news of our 04 civic (moms). 375,000 and the auto trans finally gave it up. if I can recall....
dealer traced a reverse lights wiring fault under warranty
it needed a new alternator around 200k
replacement headlights from “sandblasting” around 300k, and Home Depot hardware was used to firmly reattach the bumper.
head gasket around 345k
it might have gotten a compressor at some point, I’m not certain
timing belts serviced every 100k, presumably with water pump
aside from oil changes, i swapped 3.5 qts of amsoil atf in to the trans twice.
the car went back and forth between my brother and my mom. She is very easy on cars. My brother doesn't misuse them (he likes good equipment), but he can load them with several hundred pounds of river gear and run then WOT on mountain passes at high altitudes forever.
it was a really good car... almost reached its 400k design life. Scrap yard came and got it.
