Falex Siezure Load of Base Oils
MolaKule
Staff member
Iowegia - USA
In a Falex Load-to-Seizure Test a series of base oils were tested using the same viscosities of base oils. A polyol ester pure base oil of Pentaerythritol failed at 3,400 PSI. Pure mineral oil failed at 22% of the Pentaerythritol, but PAO failed at 253% of the mineral oil. At what PSI did the mineral oil and PAO fail? Rules for the Question of the Day: 1. No Piston Cup Lapel Pin will be awarded to the same person within 14 days of a previous award. 2. Please respond with a complete sentence. 3. Please do not post links. If a question arises as to the need for clarification, then sources and links may be requested. 4. Please, no off topic posts.
If I entered the numbers right, 1892 psi +/- calibration and measurement error.
And zero points for reading comprehension frown
Originally Posted By: Stelth
The mineral oil failed at 748 psi, and the PAO failed at 1892.44 psi.
OK but how does that relate to the best motor oil to use in a car's engine. Functionally both seem to be equal.
Within calculator round-off errors: 22% of 3,400 psi = 0.22 X 3,400 = 748 psi for mineral oil. For the PAO, 253% of Mineral Oil = 2.53 X 748 = 1,892.44 psi for PAO. So the long tall Texan gfh77665 wins the latest bright and shiny Piston Cup Lapel Pin. thumbsup The following fluids showed these Falex load-to-seizure results: Pentaerythritol (polyol Ester) - 3,400 psi TrimethylPropane (polyol Ester) - 3,200 psi Dibasic Acid Ester - 2,000 psi PAO - 1,900 PSI Chlorophenylmethyl Siloxane - 1,100 psi Petroleum Oil - 750 psi Methyl alkyl silicone - 725 psi Methyl phenyl silicone - 75 psi Diemthyl silicone - 70 psi
I do not know anything about any contests but would like to know the validity of Falex seizures as it relates to car engines today. Would it not be like saying a grade 8 bolt is better then a grade 2 bolt when all I am doing with the bolt is holding together the pages of my tractor's parts manual? Engine parts are not even touching each other if the engine is in use or else it would only last a few miles I expect.
I would recommend you start a thread in Passenger Car Motor Oil (PCMO) - Gasoline Cars/Pickups/Vans/SUVs.
My question is about the value of Falex Seizure MolaKule and I was hoping you point out the functional value of Falex Seizure testing beyond marketing hype. I think in can start a new thread if you wish that action.
We will have a series of questions in the future and in this Forum regarding various experimental methods in Tribology. In the meantime, look through the historical posts in this forum as there are a number of ASTM topics posted.
