Was curios about Factory fill YES I dumped it early but OLM was at 81% Mostly Hwy 80 /20 split I belive TBN is aprox 6.6 based upon AC delco 5w30 VOA. Engine uses timing chain so I didn't want it to be like the Traverse fiasco with the OLM getting recalibrated (service)
OIL USE INTERVAL 2377KM
FACTORY FILL 5w20
MICHAEL: It's normal to find higher metals and silicon in a brand new engine. Iron and copper are from steel and brass/bronze parts. They read higher than average here since they're from brand new parts wearing in and getting comfortable in your engine. Silicon is from the harmless sealers the factory uses to put the engine together. These materials should wash out with a few oil changes and we'll be able to compare your engine to universal averages, which are based on about 6,000 km. The TBN read 4.4, still a
good reading. Check back to build trends
Sample Date 05/25/13
Make Up Oil 0 qt
Oil Filter AC DELCO 96985730
ALUMINUM 4
CHROMIUM 0
IRON 20
COPPER 184
LEAD 3
TIN 0
MOLYBDENUM 0
NICKEL 0
MANGANESE 21
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 2
SILICON 95
SODIUM 364
CALCIUM 2119
MAGNESIUM 12
PHOSPHORUS 789
ZINC 824
BARIUM 26
Values Should Be*
SUS Viscosity @ 210°F 52.3 45-59
cSt Viscosity @ 100°C 7.98 6.0-10.2
Flashpoint in °F 445 >365
Fuel % Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.2 TBN 4.4
Thoughts on this? I will going for official Oil change end of july then will be doing every 4 Months or according or OLM
FACTORY FILL 5w20
Make Up Oil 0 qt
ALUMINUM 4
CHROMIUM 0
IRON 20
COPPER 184
LEAD 3
TIN 0
MOLYBDENUM 0
NICKEL 0
MANGANESE 21
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 2
SILICON 95
SODIUM 364
CALCIUM 2119
MAGNESIUM 12
PHOSPHORUS 789
ZINC 824
BARIUM 26
Values Should Be*
Water % 0.0 0.0
