Factory Fill, 64K, 12 Jeep Wrangler Unlimited Rubicon TCase
Texas
Drained and filled with Amsoil ATF. Make/Model: Jeep Rock-Trac (Rubicon) Vehicle: 2012 Jeep Wrangler Unlimited
Code
OIL		Factory
MILES IN USE	64,056
MILES ON UNIT	64,056
SAMPLE TAKEN	8/19/18
MAKE UP OIL	0
ALUMINUM	16
CHROMIUM	0
IRON		190
COPPER		74
LEAD		0
TIN		2
MOLYBDENUM	0
NICKEL		1
MANGANESE	58
SILVER		0
TITANIUM	0
POTASSIUM	13
BORON		77
SILICON		159
SODIUM		31
CALCIUM		269
MAGNESIUM	4
PHOSPHORUS	302
ZINC		15
BARIUM		5
SUS @ 210	43.9
cSt @ 100	5.38
FLASHPOINT	400
WATER %		0.0
INSOLUBLES %	0.0
TAN		1.2
Blackstone Comments: Universal averages for a Jeep transfer case give you an idea of typical wear after ~44K miles on the oil. Next to those, there is some extra metal in this sample, but don't be too put off by that. This is the factory fill, so a fair amount of the metal is just lingering material from the initial wear-in period plus normal accumulation over the past 64K miles. We should see a lot of progress with each oil change. No contaminants or oxidized solids were present. TAN is fine at 1.2. Resample in 65K miles.
upstate NY
Looks pretty good. My F150's Borg-Warner T-case showed 603 ppm of iron with 91k miles on the factory fill. At least I hope it was the FF with that much iron (I bought it with 81k miles). It wasn't full when I drained it, either (concentrating the wear metal ppm count).
