Here's the story: Since about 9xx miles I have been running Mobil 1 Synthetic (started with Tri-Synthetic forumla and have ended up with SuperSyn). In the winter I run 5W-30 and in the summer 10W-30. I've been running a 3k oil change interval after the car was broken in.
In the first oil analysis I was running 5W-30 and lead appeared a little high, no other bearing wear metals appear to be elevated. In the second oil analysis I was again running 5W-30 but lead is even high than before.
Here's the catch: Right before the first oil analysis I pulled the spark plugs, cleaned them off, rechecked the gap, and then reinstalled. When I installed the plugs I put a bit of anti-seize on the threads (probably too much).
What I'm wondering is:
1. Does anti-seize contain lead?
2. If so, is this lead starting to leach into the cylinder walls and then getting into the oil by the piston rings scrapping against it.
Andy
Andy
