My Exhaust air pump check valves keep going bad after about 35k miles. They freeze closed. They are made from stainless steel, so they cost more than the old plain steel type: $40+ ~vs~ $20-. When I unscrew them for replacement, they are full of water condensation. I can't see any rust inside the valve. I have tried to soak the valve in carb cleaner, MMO, Sea Foam, PB Blaster, Alcohol, WD-40, and Break parts cleaner. Nothing seems to free the stock valve. I will take one apart to see how it looks and works.
It is a 2001 GMC w/5.3L engine. It has 2 check valves: One per side. I am in Northern California, San Francisco Bay Area, East Bay. It isn't too humid
How long does the check valves in your GM, or other, vehicle last?
I am starting to wonder if the TCW-3 oil I put in my fuel tank is causing the check valves to plug. I have read that some 2 stroke oils can plug power valves with carbon, but there isn't heavy carbon build-up in the valve. The inside, from what I can see with a flash light, is clean. When I take it apart, I will get a better idea of how much carbon is in the valve.
