I was thinking before I went to bed.. what could be a really efficient car that uses less amount of oil/fluids etc.. and easier to maintain? Heres my ideas.
1. 3 quart oil sump/Engine and Manual transmission uses the oil in the same sump/ 2 different filters.. one for the engine , one for transmission. So your getting double filtered oil...
2. Clutch/Brake or anything else Hydraulic uses the same Master Cylinder and uses very little fluid
3. alternator, Water pump, power steering, ac compressor etc.. are all electrically operated .. no belts. Ok.. well.. there will be a emergency belts,, just incase some electronically goes wrong.
4. Magnetically controlled Brake system.. no brake pads.
5. Air Filter every 100,000 miles.. through it in the washing machine.. run another 100,000 miles.
6. No Spark plugs or wires. Each cylinder has has some sort of Coils.
7. Blinkers that don't require fluid...........
anybody have any ideas?
