Originally Posted By: Superflan
I’m no electrical engineer but how grounding distant from battery, given the multiple ground cables thickness, can dump current spike? When I do clamp cables, I’m more worried about voltage spike when it does sparks and crackles. And this happens even when I use available clamping points that are designed to on some vehicles.
So, the thing is I understand your concern, that YOU came to help, but maybe it’s just rockstar symptom. I’m with you on it, though nowadays I don’t exhibit it unless life-threatening move.
Even if the resistance is kept good and low, it still adds series inductance. Plus I don't think that series resistance is quite that low. All of which lowers the peak current that can flow initially.
