You're right a manual isn't for everyone. When I let out the clutch, the revs are the bare'est tick above idle (most of the time, "Grandma" starts)... I swear the clutch is fully let out at a person's walking speed. And if I wear out a clutch before the throw-out bearing buys the biscuit or the main seal pollutes the clutch disk, well, then I'm being too hard on the clutch. I've actually never worn out a clutch (but of course this depends on miles driven and how aggressively [competition use?] the car is driven...). Shifting gears, that's a whole other subject... and just like you, Eco, I double de-clutch down most times (and sometimes up, too). If it doesn't shift like velvet, or if I encounter synchro double-bump (much) I'm doing something wrong.It was in Vancouver too.
That M3 was pale blue or maybe bluish green. Quite an attractive car. If you're ever tempted to buy a used M3 that sort of colour in Vancouver, check the transmission for metal filings. I don't imagine that driving style would have resolved later the same day.
I can only imagine some wanna be enthusiast with more money than sense buying a manual M3 and only then trying to figure out how to drive a manual.
We have to hope they went back to the dealership and traded it in for an automatic. A manual isn't right for everyone.
Ever seen someone driving a manual transmission who probably shouldn't have?
Probably very true. 'Lotsa "mechanically unsympathetic" folks out there. The reason (and I know I'm 'way too picky) that I don't generally go out of my way to buy a used manual transmission car... I've seen videos made, say, in one case of an air-cooled P-car where the guy showed no sense that his shifts ought to at least recognize that there is a neutral position between gears. It was first gear then right away second gear... and the guy was NOT driving aggressively. If you don't caress that shift lever with no more than two fingers on a pull towards you or a palm away from you - at least in the case of most modern, light-duty gearboxes - you are doing it wrong (in my opinion). It has to want to execute the shift, not be forced to.Are you joking? 75 percent of Europe's habitants are sitting in cars with manual transmissions
which they aren't able to operate. Owning a manual doesn't mean you're a virtuoso.
I wish one of my two adult (35 y.o. +) daughters were interested... Oh well, it's a dying kind of thing. Manual transmissions, conceptually, are off-the-ark technology. Who ever thinks that interrupting the continuity and smoothness of the car's acceleration to shift gears is a reasonable and modern thing to do in a car...
Still it's enjoyable, and I think most of the time it makes me a less aggressive driver.
What an idiot your co-worker is/was. What gives him/(her?) license to abuse your car- and your kindness in allowing them to drive. 'Boy I don't like that .I let an Italian coworker drive my car (‘95 Integra GS-R) during lunch once. He was slamming the gears and using excessive gas between shifts.
I also do 2 finger shifts. I describe it as wishing the lever into the next gear.If you don't caress that shift lever with no more than two fingers on a pull towards you or a palm away from you - at least in the case of most modern, light-duty gearboxes - you are doing it wrong (in my opinion). It has to want to execute the shift, not be forced to.
And smooth can be very fast.I had a neighbor with a 911 that only shifted to a higher gear when he hit the redline on the tach. I asked about that and he smirked and said, “A 911 owner would know that’s the way to drive a performance car”.
My sister studied dance of all kinds growing up…she is the smoothest manual driver I have ever known. It is a dance of timing and rhythm and she does it SO well.
But to be able to be fast and not abusive, at least with the reconnection of the powertrain after the shift is made, the flywheel has to be ultralight and the revs as a result fall really fast. Also, those manually shifted 'boxes in competition cars tend to be "dog-boxes", i.e. non-synchronized dog-engagement teeth, motorcycle-like, boxes that go "clunk" when you shift, but are tough and durable... no fine synchro spline teeth.And smooth can be very fast.
I've heard of Formula 1 drivers being as being smooth. For one thing their car is more likely to last the race with a smooth driver.
Depends on the car I suppose. I'm mostly used to import makes where the clutch pedal is pretty light. I was waiting in line to get into a show in Vegas when the discussion went to cars. I said it wasn't too bad on me knees, but then the guy I was talking to said it must not have been an older American manual transmission with a heavy clutch.
I've heard of the 90s Corvette with a 1st to 4th shift (at lower speeds) where 2nd/3rd were locked out to boost fuel economy. Then I test drove a Saab 900 once. It had a light that said "SHIFT UP". And it was telling me to shift when the revs were at about 2000 RPM. It was obviously programmed to encourage better fuel economy - probably for better fuel economy estimates. It was mostly just annoying.
I’ve heard Lewis Hamilton saying that he wished that F1 would go back to a real manual transmission.And smooth can be very fast.
We just don't have anything like that over here in the States. We probably should but there are so few manuals anymore that is really doesn't matter much these days. Unless you are specifically looking for a manual transmission, you probably won't find one. I was looking around to possibly add a newer Camaro to my collection last year and I could only find 2 6 speed manuals in my area to look at. It is always funny when the dealer asks you if you can drive a stick. Each time I was driving my 94 Z28 with the manual when I went to look and just pointed to her and said "What do you think that is?" and laughed. But I'm sure they get plenty of idiots that have no idea how to drive one in there to look at them and can't get them out of the lot like my old friend did with that Mustang.I still find it ludicrous you can pass your test in an automatic in the US and the next day drive a manual. In the UK unless you're disabled you generally learn and pass your test in a manual. If you pass your test in an automatic you are only eligible to drive an automatic.
All 3 cars in my signature are manuals. Much prefer an automatic for daily driving but there is something enjoyable about having that bit of extra control over your car.
Did she rip her jeans learning to shift?My dad bought my four siblings and I stick cars and taught us how to drive them. My mom had no trouble driving my dads S10 that had a stick.My wife has an Audi with a stick. I taught my niece how to drive a stick and she has a Civic Si with a stick.
