So my overflow tank is one of those unpressurised designs, with a simple snap-on plastic cap that appears fairly watertight. It is exactly this one.
I've been monitoring the cold coolant levels weekly, and noticed that over two months or so, the level would drop about 1cm or so, corresponding to a loss of between one to two ounces. This is happening even with a fairly new radiator, rad cap and hoses, which are bone dry and by now covered with a layer of dust (no evidence of leaks). The radiator neck and external surfaces of the overflow tank are likewise. Zero coolant smells when the heat is on. Head gasket appears good, oil has no evidence of coolant in it at the end of each OCI, and the engine as far as I know has not overheated in its lifetime.
So I get a little frustrated with getting nowhere on this and start sniffing around my engine bay after long trips. Upon lifting the hood there is no coolant smell. I stick my nose next to the radiator cap - no coolant smell. But when I stick my nose next to the cap of the overflow tank, I catch a very brief whiff of coolant sometimes. It lasts not more than a few seconds and it becomes imperceptible again. I check the cap, it looks perfect, as does the mouth of the bottle. The cap snaps back on with a reassuring click.
I'm wondering if minor coolant loss such as what I observe is normal for unpressurised overflow bottles. It is obvious that the cap does let out minute amounts of vapor (by design??). FWIW, I'm running a premixed green coolant at 30/70 v/v, so it's got quite a bit of water right out of the bottle. What I'm also wondering is if it makes sense, and/or if it could be in any way detrimental to perhaps stick an O-ring into the groove of the plastic cap to try to create a tighter seal.
