I'm not necessarily a big wind fan, just impressed that the costs keep coming down, same as solar. Eventually they'll make more sense. Nuclear and gas have hit the point where the costs aren't coming down and increase with time along with inflation. Also I believe the larger wind turbines actually claim the opposite, they can work with lower wind speeds which give them the higher capacity factor. I think your data was for on shore wind, doesn't seem to be that much data for off shore wind. Will be interesting to see how much bigger they can get.
As I noted earlier, cost is just a small part of it. Wind is installed because it's a quick and easy compliment to gas and many of the same companies own both so it makes for an easy virtue signal. Serial construction of standardized designs drives-down cost, that's why Russian nuclear plants are currently quite inexpensive compared to Western designs and why China has settled on the Hualong One for their own domestic builds. This is supposed to be the big driver to reduced cost on SMR nuclear.
At some point we need to decide whether the goal is just high penetration of renewables or deep decarbonization, because they are not the same thing. A high wind grid is not a low emissions grid, but it's an expensive one due to the acrobatics required to make such massive amounts of intermittency work.
Read the Capacity Value article I linked earlier, at some point these technologies start sabotaging their own markets because "more" doesn't mean "more right now". You end up with bigger peaks of output and the same lulls where somebody else steps in, so market value continues to decline while market price, to prop it up, continues to climb. Nobody is going to build a generator that doesn't make money and fuelled sources will simply demand more if they produce less.
No, eventually they won't make more sense, that's like saying eventually the square peg will fit in the round hole, you just need more pegs, and the pegs need to be cheaper. It doesn't change the fundamentals of grid operation or redefine demand profiles. Not producing power when it is needed is, and will continue to be, the problem.
Solar works, as long as penetration is constrained, to depress daytime peaking. The limit on penetration is key, because it works reasonably well as long as you don't start cannibalizing your baseload sources. Once you do that, and drive them out of market, then that capacity gets replaced by fast-ramp peaker capacity which is more emissions intense and more expensive. So then your "cheap solar" makes power more expensive because backup capacity isn't going to be built, or operate, if it can't make money. If you drive out ultra-low emissions sources like nuclear, then your grid also gets dirtier too, taking things the opposite direction. There are of course stability implications as well, as even things like a fast roll-in of cloud cover, if a larger portion of the grid is solar, can destabilize things. Large generators do FCAS as part of their standard operation and provide inertia, something that solar and wind lack.
On the predicted higher average CF, this comes from projections for more, and more consistent wind conditions at higher altitudes. It appears that the cut-in speed for most of the larger models is the standard 3m/s that it was for the 3-6MW units. GE hasn't made the cut-in available for the one we are discussing but I did find some for another 12MW turbine and it was the same.
