I've been chasing down the cause of ignition misfire in my wife's 1997 BMW 328i for a few months now. The most recent UOA with German Castrol can be found here: 1997 328i UOA
I've gone through spark plugs, a new battery, camshaft position sensor and ignition coils (the last two due to OBD-II fault codes). I thought I had the problem licked and then it returned after a week or two.
Finally, I was in the midst of swapping ignition coils from one cylinder to another to see if the problem would follow the coil when I saw that there was some oil in the spark plug hole. Not a lot, just a very thin film. What appears to be happening is that everytime I did something, the problem would go away for a week or so. Then the oil film would return because of a weeping valve cover gasket and the car would start misfiring again. BTW, I can't detect any change on the oil dipstick over the course of 7,500 miles. This misfire first started back in December when I put German Castrol in the car, now that I think about it. Before then, everything was fine.
So, do esters being polar in nature, cause oil to be more electrically conductive? It would appear so in this car.
