Esso XD-3 Extra 0/40 ?
Oklahoma
Do any of you that live up North or in Canada have any experience with the Esso XD-3 Extra 0/40 ? I also have heard of a 5/40 Ultron but cannot locate it on the web. Any pricing on the 0/40 you can post ?
Here is the page,while there read " Esso on Glycol " in newer oil formulations.
Glycol Negativity
(During colorimetric glycol testing, some new oils will show positive results. This can be confusing and expensive for conscientious operators. ESSO XD-3 EXTRA is glycol negative meaning that if there is no coolant in the oil, the test will not give you a false indication that it is present.)
Which might be related to this that I posted awhile back?
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=4;t=000132
Esso site: http://www.imperialoil.ca/products/lubes/index_lubes.html
which will not display the page for some reason,you have to hit product info,then Industry,then Forestry to find the XD-3 Extra 0/40
[ January 23, 2003, 11:09 AM: Message edited by: dragboat ]
I always fill up at Esso for gas so next time I'm there I'll see if I spot this stuff. I don't recall ever seeing it though.
Esso XD-3 0W40 was re-formulated last year after the CI-4 specs were introduced.
The new version is lighter colored at a 3.5 instead of 7.
The VI is down a little, and the 40C up a little along with the flash point.
When this oil first came out I tried it in two vehicles with good results.
One of the engines had a highly loaded valve train which "lived" through the test.
Esso lists the oil as a PAO.
I think the current wholesale price is around $3.90 CDN/litre or $2.80 USD/qt.
