The oil is Esso XD-3 0w30 that's been in the van for 10000KM. I was losing coolant from the overflow bottle, but couldn't see any external leaks, hence I had the UOA done.
FYI, the numbers in the second column are from German Castrol in use for 2259KM, 3.8 V6 from the same Grand Caravan, but not the same motor. It was the original v6 in the van that had a leaking intake gasket and a UOA confirmed glycol in the oil. Shortly after having it fixed, the motor spun a bearing. I put a used motor in, and now have the same problem with disappearing coolant in the new used motor...obviously I've offended the engine gods somehow...
________________________________
CONTAMINATION XD-3 GC
Silicon 13 7.1
Potassium 432 187
Sodium 236 295
Fuel % Glycol P os P os
Water Soot --- ---
Sulfation 67 36
Nitration 55 34
___________________
WEAR XD-3 GC
Iron 21 5.0
Nickel 0.0 0.0
Chromium 0.9 0.2
Titanium 0.1 0.1
Copper 1.8 0.9
Aluminum 7.1 1.4
Tin 0.6 0.0
Lead 4.1 1.8
Silver 0.0 0.3
OIL CONDITION XD-3 GC
Boron 11 3.4
Barium 0.1 0.1
Calcium 3123 2573
Magnesium 13 109
Molybdenum 7.8 9.0
Sodium 236 295
Phosphorus 1297 763
Sulfur 3714 2480
Zinc 1270 974
Visc @40 --- ---
Visc @100 11.1 11.7
Oxidation 61 50
Silicon 13 7.1
Potassium 432 187
Sodium 236 295
Water Soot --- ---
Sulfation 67 36
Nitration 55 34
___________________
WEAR XD-3 GC
Iron 21 5.0
Nickel 0.0 0.0
Chromium 0.9 0.2
Titanium 0.1 0.1
Copper 1.8 0.9
Aluminum 7.1 1.4
Tin 0.6 0.0
Lead 4.1 1.8
Silver 0.0 0.3
Boron 11 3.4
Barium 0.1 0.1
Calcium 3123 2573
Magnesium 13 109
Molybdenum 7.8 9.0
Sodium 236 295
Phosphorus 1297 763
Sulfur 3714 2480
Zinc 1270 974
Visc @40 --- ---
Visc @100 11.1 11.7
Oxidation 61 50
