Hi,
I have a question I have been pondering for some time now, and I figured if I had it in my head, someone else had it too.
The question is this: How long can a typical engine last (ignoring certain unusually robust ones) with no oil in the sump before engine damage starts to set in?
There is a certain amount of oil that is left on the bearings, journals, rings and valve guides that is left behind after the oil is drained. But how long will that remainder last before it becomes unsafe to continue running it?
As for a story, this question brewed out of an incident I had long ago, about 10 years ago. I just got off work for a 3 day weekend, and hit a side road on the way home. I punched the gas on my '88 BMW 325is (who wouldn't, it ran exceptionally well) and the oil pressure light came on. ???? went through my head. There were two possibilities: The voltage supply line to the oil pressure sensor wraps around the front of the block, and is hardly protected well, and it may have been severed. Or I had a serious mechanical failure of some kind.
The next day when it wasn't at night I examined the wire. It looked fine. So I started the engine for 5 seconds to see if it was a fluke. Nope. Okay, take off the oil filter, put a rag on the mounting plate, start it and run it for 5 seconds. Not wet. If there was oil, there would have been oil on the rag.
A small piece of metal about the size of your small finger nail had somehow gotten inside the oil pump and seized the gears. Of course the engine doesn't know anything about that and kept chugging on, and snapped the oil pump driveshaft. Total bill: About 750$.
