The original U-joints got 12,000 hrs of fairly LIGHT use on them. Call me crazy or not, I can feel a little more wear than I want, considering there are no plans to sell this tractor, unless my parents have to quit farming because of the price situation (pork vs. swine feed). The joints are not totally worn and have not failed, they are just leaking grease and obviously, the cross and the needles got some dark spots that can't be wiped off with acetone. To me it looks like a mix of EP-additives and surface fatigue, maybe even solid lubricants, I don't know.
No matter what, I will be installing some zerks in the caps, as the yokes do not leave the room for a center mounted zerk. 1 - 2 shots of fresh grease every 3 - 400 hrs. would be my suggestion.
The genuine u-joints might be the way to go because of the superior needle setup. Their downside is the smaller body + the longer arms. I may add that a genuine Carraro joint costs 55% of what the greasable high quality GKN joint costs.
That's just me thinking, or over-thinking.
