Originally Posted By: Rohan
2002 Honda Odyssey 421k
I installed the new thermostat (not OEM). Both fans are coming on at 235F then it will goes back to normal temperature which is 180F until the fans turn off. Is this normal? I did changed the coolant and bleed the air so many time. Yes, I did the combustion leak test and the results was negative.
Parts that been changed;
Thermostat
Thermostic switch A (on thermostat housing)
Thermostic switch B ( NEVER been changed, located somewhere on passenger side of the engine)
Upper & Lower Radiator hose
Why in the world would you install an aftermarket thermostat in a Japanese car?? Aftermarket thermostats are junk. Replace it with an OEM thermostat before your engine blows up. Also, make sure that the jiggle valve points up if there is one.
Thermostat
