JHZR2
Staff member
LOL, if you only knew...quote:
Originally posted by Tempest:
some navy ships...: more power with less weight with higher reliability and less noise.
JMH
Tell us more...quote:
JMH
It does pose a problem if there's no alternative to platinum--especially at its current price!quote:
Originally posted by HardbodyLoyalist:
Catalysts pose nowhere near the problems "cheap" hydrogen does--to say nothing of its storage and transport.
turbine engines only like to run in a narrow RPM band and have slow throttle responce. one example is a turboprop engine runs at a constant rpm-always, aircraft speed and power is determined by blade pitch. another example is a turbine engine could take 7-10 seconds to go from idle to 100% rpm, very slow compared to recip engines.quote:
I really don't understand why rotary or turbine engines don't rule. Their non-reciprocating nature makes them more effeciant, lighter, smaller, and with fewer moving parts than the dinosaur piston engines that we have now. Coupled with a CVT, it should be the ultimate drivetrain.
There is a reason why aircraft, helicopters, some navy ships, and even the M1 tank use turbines: more power with less weight with higher reliability and less noise.
My understanding is that the Mazda RX8's engine is roughly half the size/weight of comparable output engines, and is one of the reasons for the cars great performance (along with the twin turbos).
Why is it then that they use a 1500HP multifuel turbine engine on the M1 tank? The M1 is the "hot rod" of all main battle tanks. Diesel piston driven tanks don't compare. It is very quiet compared to diesels.quote:
turbine engines only like to run in a narrow RPM band and have slow throttle response. one example is a turboprop engine runs at a constant rpm-always, aircraft speed and power is determined by blade pitch. another example is a turbine engine could take 7-10 seconds to go from idle to 100% rpm, very slow compared to recip engines.
One of the M1s biggest drawbacks is it's high fuel consumption. It's an old turbine so is even worse than a modern one. The T-type power pack arrangement takes up even more space than a modern diesel.quote:
that turbine engine also uses 20-50% more fuel then a diesel and costs 10x more.quote:
A turbine needed to power a car would not need to be all that large. And with the mass production capabilities of modern auto plants coupled with fewer moving parts, I thinks costs would come down quickly.quote:
a new turbine engine of any size costs more then a new car + new house + a year's salary. you can't really make them "cheap".
Along with greater performance. Most other diesel tank engines are in the 750HP area.quote:
Again, it all comes down to scale. There are what, maybe 3-4000 M1 tanks out there? With production of those spread out over 20 years. Your talking about building just a few units a year, and those have to meet Mil spec with all the associated paperwork and bull **** that drives prices through the roof. Auto manufactures pump out those numbers in a week and don't have the Mil spec overhead.quote:
and costs 10x more.
The NBC/Overpressure system sounds right. I wasn't involved with those people at GD but have run across Garret in NBC/Overpressure system work at another company. Also APUs.quote:
XS650: Thanks for the info. I'll have to look that up when I get some time.
As I recall, my Dad said they were working on heat exchangers for the engine. My Dad did a lot of work with those. I believe in the end though that the contract went to another company. My Dad said they had to get special permission from the EPA (Cali) in order to run a 24hour engine test even back then.
I also recall them working on the NBC/overpressure systems and some others that I forgot about. It's been a while.
Union Pacific Rairoad ran a gas turbine locomotives for awhile. They was very powerful, and not as efficient as a diesel. The stopped one under an overpass once and melted the asphalt pavement on the road above it with it just idling.quote:
Originally posted by Winston:
Chrysler made a Turbine powered car in the 60's. I saw one at the original Harrah's auto museum. There is a guy with a web site about it. His dad got to drive on for a few months.
http://www.turbinecar.com/turbine.htm
The thermodynamic cycle of a turbine engine is much less efficient than the thermo cycle of a 4 cycle gas engine (otto cycle). Then again the diesel thermo cycle is more efficient than the Otto cycle.
Turbines are too innefficient for cars.
I take it you haven't driven a Model T lately. Yup, it had a two-speed planetary, but each of those speeds had an infinitely variable friction contraption that changed the ratio as you pressed on one of the two 'forward' pedals (there was a third pedal for reverse). A far cry indeed from a modern CVT but not all that different in concept.quote:
Model T had a two speed planetary transmission, about as far from a CVT as you can get...
Your old tractors wouldn't have come close to a modern engine in lb/hp hr under normal driving conditions. If they were gasoline engines, they wouldn't have been as good under any condition. care to post some numbers from a reliable source? [/QB]
I take you have never driven a Model T or seen a T transmission taken apart. There is no variable ratio device in one.quote:
Originally posted by Lazy JW:
From my book "Nebraska Tractor Tests Since 1920" by C.H. Wendel.
Test #0766
Gasoline fuels, the all-time best fuel economy at full rated power was the 1960 Oliver 1800 which developed 13.18 horsepower hours per gallon. I converted that to pounds once but don't have the numbers handy.
Joe
Turbines are less fuel efficient that recip engines in real world automotive applications. So are rotary engines.quote:
