Originally Posted By: George7941
You omitted two facts. Only the primary side has low voltage, the secondary windings carry 10kv plus. Even on the primary side, the voltage shoots up to over 300v at the point of current interruption because of back emf.
Secondly, even if the voltage is low, the current is relatively high, at 4 to 5 amps, and this leads to heat generation in the windings.
Well, that's why I said 'relatively' low voltage--I probably should have been a little more clear.
I was figuring (though I don't know this for a fact, which is why I was asking the question!) that even those voltages and currents were low relative to the capacity of the coil. While there will be some degradation of resistance in the coil over time, it would seem that unless there was a catastrophic event the coil windings should last the life of the car.
As I said though, I certainly don't know this, which is why I was asking in the first place. Do you think the degradation in resistance of the coil over time is significant enough that it would merit replacement at a specified interval?
