I realize this is an oil forum, but I am posting here just in case my problem is oil related.....
I have a Subaru Legacy 2.4l. About 1000 miles earlier I successfully did a complete flush of the transmission including the torque converter and a filter change. The fluid level is fine and the oil still looks like new. However lately, when I start the engine and place the transmission into D, the gear does not engage. Sometimes I have to cycle to "1" and back before it engages, sometimes I place it in N or P, rev the engine and then place it into D and even then it may not engage. After a while it will engage. Once I start driving its fine and at stop lights it seems to be fine too. This problem only seems to happen when the engine is started and it does not matter whether the transmission is hot or cold. As the Subaru is a 4WD, there is a clutch at the rear end of the transmission. There is only one adjustment screw for the band on the casing. I know that the computer does control some of the movements via solenoids in the transmission.
Disconnecting and reconnecting the battery (ie. reseting the computer) does not make any difference.
If anyone has any ideas what might be causing this please share. Thank you.
