Got a physical therapy pool (commercial) and whenever a very heavy person uses the underwater treadmill, it will overflow the pump resivoir and the fluid goes all over the floor of the mechanical room. It is a 3phase 208/230volt pump, and then the hoses go thru a dry well and then drop right down into the pool to the underwater treadmill hydraulic motor.
Because there are no leaks and not water in the oil, does anyone have any ideas?
Forget its a pool, its just a pump, flexible braided hoses, and an hydro motor under water. Just typical hydralics.
