Close. Prius Prime.
They put $10,002 in rebates and tax incentives on it, and the dealer knocked some more off. Unlike my wife, I was fine with grey paint, which 90%+ of prii come with.
Dealer delivered it with a full tank of gas, but empty battery, a common occurrence from what I've read online.
Car is advertised to have ~26 miles of electric range, accurate. To add to "range anxiety" the heads-up-display shows a running tally of battery percentage that ticks down from 100 to 1, about two ticks a minute.
Car has "Jesus take the wheel" mode when it thinks it's getting out of the lane. Turned that off. Felt like I was driving on icy roads because the car was moving laterally without my input.
They changed the LED headlights somewhere between 2019 and 2021. High beams are now "quad" and nice. The low beam cutoff is still an annoying razor sharp line that's bothersome on hills.
I think my gas MPG is around 65. With my electric boost though it's well over 100. I pay 14 cents/ KWh and figure this is about 30% cheaper than gasoline. Time-of-day metering options for me are unattractive-- Four or five cents surcharge in the morning and evening for a penny off the rest of the time. Don't think I'll be signing up. Takes 6.6 KW for a full battery load.
Car comes with a level 1 charger, 12 amps at 120V over six hours. I popped a 15 amp breaker with nothing else on it so am putting in a dedicated circuit and improved garage subpanel as soon as I can get parts. (Covid has hit electrical parts too!)
There's seating for five now unlike previous years of the Prime-- the enlarged battery used to take a rear seating position. Now it takes trunk space with a high load floor. Also, oddly, the rear glass swoops down in the middle, guzzling trunk space but improving aerodynamics. There is no rear wiper-- if they made one it would have an odd path and lots of flexing to do.
Electric only mode is, dare I say it, peppy? Jackrabbit starts might be guilt free, though they're plausibly fatiguing to the battery pack. If I am driving on electric and the battery runs down to zero, gas mode is notably less peppy. They could do some work with the DBW throttle mapping.
This car (LE trim) has XM and HD radio, but no blind spot monitoring in the mirrors. First car with seat heaters, but this is to let you run a cooler cabin. It uses a heat pump for heat, crazy! Gas engine runs if it dips below 14'F. I force gas mode to drive to work then use electric to come home, feel it uses each powertrain's strengths.
Toyota still recommends 5/10k OCIs, same as the regular prius, despite this car possibly running much less. IMO it should have an engine hour meter or smart OLM. I may change it every 15 tanks of gas once out of warranty.
