I wonder about the claim that a bypass filter will eliminate wear and oil changes read this .It was a spectacular field trial. And it was something
of a nightmare.
Life On The Streets
It was 1984. Lubrizol, the prestigious specialty chemical supplier, launched an ambitious testing program for its additives and formulations. It involved finding a fleet whose normal use exposed the cars to a wide range of stress. One by one, the existing engines would be removed, and replaced by factory new engines. Completing the tests, the fleet's new engines would be removed and disassembled for inspection.
The fleet chosen was made up of New York City taxicabs. Here was a pool of automobiles subject to long periods of idling, strenuous bouts with traffic, and an occasional "follow that car!". Or "get me to the airport no matter what," accompanied by the full range of weather and temperature variables. A classic choice in field testing.
But there were other factors the testers couldn't anticipate. Once the tests began, an astonishing rate of smashed and disabled cabs emerged. The test fleet seemed to ricochet through the New York streets like billiard balls. Added to this was the Chevrolet 229 CID V-6, an engine in its last product year and remembered foundly by mechanics everywhere for its ability to produce income.
Like all field tests, real-life testing would provide something the laboratory never could. Unpredictability.
Welding The Plugs
The AMSOIL test involved sixteen cabs divided into four groups of four cabs each. The first four were controls. Using the same petroleum oil and filters already in use by the fleet, they would follow the existing fleet custom of changing oil every 3,000 miles. They are identified as "Group A".
"Group B" used AMSOIL 10W-40 Synthetic Motor Oil with an AMSOIL Oil Filter. For Group B, the oil change interval was doubled to 6,000 miles.
Using the same AMSOIL products as "Group B", the third division of cars - "Group C" - quadrupled the control interval, changing oil at 12,000 miles.
Click on Picture to Enlarge
Group A, Unit 100: Control, Petroleum oil, 3,000-mile drain interval
Group B, Unit 076: AMSOIL, 6,000-mile drain interval
Group C, Unit 070: AMSOIL, 12,000-mile drain interval
Group D, Unit 074: AMSOIL, No oil changes, 60,000-miles
But "Group D" ran the ultimate test. Using AMSOIL 10W-40 Synthetic Motor Oil, an AMSOILS Oil Filter and AMSOIL By-Pass Filter (changing the filter at 12,000-mile intervals), the taxis were "filled for life". No oil changes at all. In fact, the drain plugs were welded to the pan.
The life of the test was 60,000 miles. Overall, the AMSOIL test fleet accumulated nearly ¾ million miles.
Inside The Engines
With the tests completed and the engines removed and disassembled, there was no visible evidence that an AMSOIL-filled engine without an oil change in 60,000 miles was worse off than a cab with 20 petroleum oil changes. A systematic analysis of sludge, varnish, rust, and wear showed little variation between taxis with AMSOIL products and those without, even though AMSOIL oil change intevals ranged from double to twenty times the petroleum-filled engines.
In its written conclusions, the testing facility responsible for compiling the test data made this observation:
"The data presented in this report indicates that AMSOIL synthetic SAE 10W-40 passenger car motor oil formulation as desribed here provided protection of test engines from excessive wear and deposit formation far beyond the normal 3,000-mile change interval."
In a separate letter to AMSOIL's Technical Director, the testing facility diplomatically touched on the problems caused by using the Chevrolet engine for testing, while agreeing with the long-drain conclusions produced by AMSOIL Synthetic Oils:
"I believe the general conclusion that your 'four times normal drain' engines appeared as clear as our mineral oil 'normal drain' engines is testimonial to your oil, in spite of the unanticipated severity of the General Motors 3.8 liter engine."
Adding It Up
In the end, the long, grueling test, so riddled with the unpredictable events of real-life, pointed to a product vastly better than ordinary petroleum. It established base-line data that supported AMSOIL recommended drain intervals of 25,000 miles or one year. It gave visible evidence of how AMSOIL Synthetic Oil behaved in the worst of circumstances. And it established the role of the company's synthetic lubricants in the looming age of conservation and environmental awareness.
For those who used their vehicles to make a living, it promised a way to make the vehicle last longer, have fewer down hours for general maintenance, and a way to increase the profitability of their business.
N.Y.C. Field Test
Deposit and Wear
Sludge*
Deposits Varnish*
Deposits Rust*
Deposits Cam + Lifter
Wear
A. Control Group: Petroleum
3,000 Mi. Oil/Filter Change 9.5 6.1 10.0 .02-.06"
B. Group B: Synthetic
3,000 Mi. Oil/Filter Change 9.6 7.0 10.0 .01-.03"
C. Group C: Synthetic
12,000 Mi. Oil/Filter Change 9.4 7.1 10.0 .01-.03"
D. Group D: Synthetic
Fill for Life 9.5 6.6 10.0 .02-.05"
* 10=Clean Duration - 60,000 Miles Per Vehicle
of a nightmare.
Life On The Streets
Welding The Plugs
Inside The Engines
Adding It Up
N.Y.C. Field Test
Deposit and Wear
Sludge*
Deposits Varnish*
Deposits Rust*
Wear
