The nozzles are only slightly bigger than stock -- though if I end up replacing them I will go up one more step.quote:
Originally posted by TooSlick:
The oversized injectors are enough to cause these fairly high soot levels. Combine that with a high mileage engine with more blowby and I don't think your soot levels are abnormal at all. I've seen soot levels as high as 3% after 10k miles with some of the earlier Passat TDI's.
I'm pretty sure I really don't have a silicone/silica problem. I think it's an artifact from the virgin oil.quote:
The increase in silicon would also indicate you're seeing more blowby with the 0w-30 and this would also result in higher soot levels in the oil.
True. I have been focusing mostly on other questions, and ignoring viscosity. Back when I knew even less about oil than I do now, at least I knew that older engines often required a higher viscosity oil.quote:
[Generally, using a thin oil in a high mileage diesel engine with significant soot levels is "contra-indicated", as my Doc likes to say. There is only so much you can do with additives - you still need separation of moving parts in the valvetrain and this is first and foremost a function of viscosity.
I'm afraid that's very unlikely with a modern, small diesel engine. If you want that kind of longevity, you should look into getting a late '80s MB 190D 2.5 liter 5 cylinder turbo diesel engine.quote:
I'm planning on getting about 600k-700k miles without a tear-down.
I've heard that VW designed the TDI engine to last 25,000 hours. That would be about 12 years or about 600k miles for my Golf. I don't expect the turbo to last that long.quote:
My TDI runs pretty much continously during the day, so usually the only cold start is the first one in the morning.quote:
You'll find diesel taxi's going that long,but the engines are rarely shut down and see few cold starts during the day. That makes all the difference in the world....]
The pumpe duse injection system works pretty well, it seems, but common-rail may be cheaper to produce, and probably cheaper to fix.quote:
Originally posted by Moribundman
Used cars with diesel engines used to be very popular in Germany. People would not hesitate to buy high mileage disel vehicles. The past few years, selling diesel engines, especially VW diesel engines with over 200k km (over 125k mi) has become difficult. Especially the PD diesel engines seem to wear out earlier than would would hope or expect. Maybe that's why VW is dropping the PD design and moving on to common-rail diesel?
I did not mean to imply that the PD design will cause engine damage.quote:
The kind of injection system is not really relevant to the durability of the power train. An injection-pump failure rarely causes damage to the engine.
