Miles on oil 4,000.
Miles on vehicle 110,000-114,000 .
Make up oil 0.5 lit.
Oil was in use during spring and the car was aggresively driven(above 4.000rpm, 50% of the time)
Analysis was performed by elf laboratories in Belgium free of cost under the ANAC program(they are testing for free their oil).
Wear
Iron 27
Lead 1
Copper 8
Tin Chromium 4
Aluminium 7
Nichel
Contamination
Si-Foreign 6 (
OEM filter with 40K on it !!)
Water % OK
Cooling Liq OK
Oil
Detergency OK
Visc.100 C 12.0 (starting visc. 14.8)
Wear coefficient 1,01 green color flag( there is a scale of 1,2,3,4) .
Comments
Satisfying diagnosis results. No deviations.
To allow a more precise diagnosis we ask you to note the correct engine type on the appropriate form.
Wear
Iron 27
Lead 1
Copper 8
Tin Chromium 4
Aluminium 7
Nichel
Contamination
Si-Foreign 6 (
Water % OK
Cooling Liq OK
Oil
Detergency OK
Comments
