I put a small generator in my motorhome (not the kind made for a motorhome) to run the air conditioner. But running the land line to the generator doesen't work. It overloads and kicks the circuit breaker on the generator. The land line includes a power center that charges the two house batteries and runs 12 v lighting, etc. (The power center runs the 12 v items off the house batteries and then when the land line is plugged in to 110 v, it switches to charging the house batteries, runs the 110 outlets in the motorhome, and converts 110 to 12v to run the 12 v items.)
I am thinking a direct hookup to the air conditioner, bypassing the power center, may reduce the load by 2 or 3 amps and make it work. But I need a way to switch it so that at a campground the air will run off the land line hookup.
Here is my idea. I will splice the neutral and ground leads from the generator into the neutral and ground of the air conditioner and use a 20 amp (sufficient for my air con) three way light switch on the hot lead so I can switch from the generator to the land line. The neutral and ground should not matter being hooked to both the generator and power center since with the switch only allowing one or the other, there would only be a complete circuit for the power source that is in use. Right?
Or would there be back feed along the neutral?
(I know with my fridge on an inverter I had to isolate all three lines with three three-way switches (modular ganged in one wall plate).)
