I have a 2005 Silverado with an undiagnosed electrical issue. Back in June I started it and after a few seconds, the engine slowly revved up to about 2500rpm and died. It cranked over fine but wouldn't start. I tried a lot but assumed the fuel pump died.
Last month I tried starting it again just to see and it started up fine. I've been using it somewhat regularly. I generally baby the motor to save gas but I pulled onto a road and accidentally pulled out kind of close to someone. I took off fast and it shifted at about 4500rpm. Maybe 10 seconds later the engine started dying and hovered around 400rpm at 55 mph. It then died and I had to prevent it from rolling over in a ditch since everything else died.
Luckily after many attempts it started back up. I then remembered that the night before it first died in June I was driving it hard to "clear" everything out and get it going since it mostly just sits. Maybe a coincidence but it does seem that when it's driven hard, it'll end up stalling and may not start up again for months?
I'm not sure where to start looking.
