electric antenna for 94 Camry
Near the beach in Delaware
Within the past month my Camry has developed the most annoying buzzing that seesm to last for 20 seconds once the antenna is all the way up. If it lasted any longer I'd get a headache. The antenna does look to be all the way extended, but thats from looking in the mirror.
Can I lubricate it with something (????) or do I consider a new antenna which I saw for $16.95 on EBAY.
Yes, you can lubricate it with the following:
(1) a thin coat of lithium white grease
or
(2) thin coat of regular wheel bearing grease
or
(3) dry graphite lube (assuming that rain does not wash it off)
I use some Moly based wheel bearing grease on my wifey's 93 Camry Vee 6. Worked like a charm!
