Edge 5W-30 7.9k miles '13 F150 5.0
upstate NY
This run (so far) was from early May to a few days ago. I plan to leave it in for a few more months (I guess...I'm anxious to check the magnetic plug). I will update when I finish the OCI. This sample was to check for any abnormal wear readings. Many of you have heard about the Coyote ticking noises; well mine does not tick at all. However, since I put this oil in, it has had three episodes of valve-train clatter. Each time the clatter was heard, it started roughly 30-45 seconds after a "cold" start and it was plenty loud. The first time was the very first start after installing this oil and filter (Fram Ultra), then again in the summer and once more just recently. In each case, it continued until I shut it off; when restarted seconds later, it was quiet. shrug It never made a noise during the previous two OCIs. This OCI does include a bunch of very cold weather starts, but the previous OCI includes all of last winter (many brutally cold weather starts). No make-up oil added during either OCI. Both times, the oil was down a few ounces. This 5W-30 is dexos1 Gen 2 Edit: this OCI, the oil was down just a few ounces. I believe the last time it was down perhaps 16 ounces. I'm far from home and can't look at my records at the moment.
Code
Oil:       Edge 5W-30     Edge 5W-20
Filter:     FU 10575     Fram orange 10575
Oil use:    7945 miles     9557 miles
Odometer:   104791          96846
Copper        1               2
Iron          9              17
Chromium      0               0
Aluminum      1               7
Lead          0               0
Tin           0               0
Silicon       6               9
Sodium        5               3
Potassium     0               3
Boron        22              65
Moly         71              65
Nickel        0               0
Silver        0               0
Titanium      9               6
Calcium      852            2207
Magnesium   1398              9
Zinc         781             785
Phosphorus   602             604
Barium       0                0
Oxidation     24             27
Nitration     15             13
Sulfation     34             46
Water          N             N
Antifreeze     N             N
Fuel           N             N
Visc @100c    10.6          9.7
TAN           N/A           6.19
TBN           N/A           2.3
PFC          2.63           2.55
(Percent Fuel Content)
PQI           9              6
(Particle Quantifying Index)
dustyroads
upstate NY
Sorry, sorry, sorry.... I did not run an orange can Fram for the 9557 miles on the previous run. I originally tried posting three OCI samples but after some time I had to give up and save time, so I only posted two samples. On my very first OCI on this truck, I used Motorcraft oil and a Fram orange can. They worked great, but skipped it here. The 5W-20 run for 9557 miles had a Purolator Boss filter. I just finished a 14 hour day and not at my best now. My apologies for the goof.
dnewton3
Staff member
Indianapolis, IN
Originally Posted by JLTD
Looks like your engine prefers 30 over 20......
Your basis for stating that?
In the shop
Looks very good Dusty. Thanks for posting this smile
Houston, TX
I would say look to the filter for the valve clatter for a leaking ADBV. However, it continued till you shut it off? How long was that? I heard valve clatter on my '13 5.0 when first starting up after an oil change (priming the chain tensioner). So that is normal. But it did not last but a few seconds.
On another site
Same oil manufacturer, the 30 has much lower wear metals. Fe for example is 1 ppm/882 miles per 1 ppm/562 miles for the 20. That's 150% more to me. I'm not a statistics guy, perhaps that's within some sort of metric for "doesn't make a difference". Pardon my ignorance if statistically it may not be significant; but to me that's a measurable improvement in wear.
dnewton3
Staff member
Indianapolis, IN
Sure - it's the same oil maker. But it's not anywhere near being the same formulation; note the Ca and Mg levels. I am a statistics guy; a statistical process quality control engineer to be specific. It is IMPOSSIBLE to say with any credibility which oil did "better" with the limited data we have. Both these lubes are running well within "normal" bounds, in terms of macro data. One sample each is a laughable anecdote in terms of micro data. the 5w30 did 1.13ppm/1k miles; the 5w-20 did 1.78ppm/1k miles. Those are both totally and completely within normal bounds. https://www.bobistheoilguy.com/used-oil-analysis-how-to-decide-what-is-normal/
On another site
Thanks for the expertise. I had a couple of statistics classes; not for me. I do understand that numerous samples from this vehicle would be required to even start to statistically validate my statement; however from a 2-sample snapshot it appears there is more wear with the 20, that's all.
Florida
One has 1,500 miles of extra use on it. Kinda hard to make a reasonable educated conclusion with that data. It's not an even comparison. But definitely safe to say that an 8,000 mile interval will have less particles in it (assuming the oil filters will work the same.
dustyroads
upstate NY
Looks like your engine prefers 30 over 20.....but not the Exge if it's making a racket at startup.
The clatter has happened just 3 times in all those miles, otherwise it sounds great. I'm very happy with it. I was just playing around when I put 5W-30 in, but I do like the higher HTHS for the low rpm operation. When passing through a town at ~45 mph, it will typically remain in top gear at ~900 rpm and with gentle pressure on the go pedal, will just accelerate back up to speed without dropping a gear.
Originally Posted by Snagglefoot
Not sure why the two are so different in calcium and magnesium. Is one a D1G2 and other is not?
That's correct, only the 5W-30 is dexos1 Gen 2. I'm not sure if the 5W-20 was even labeled as dexos1. I think Castrol had gone to labeling/licensing only 0W-20 and 5W-30 for d1.
Thanks Adam. Good to hear from you. thumbsup
I had considered changing the filter, but other than the three times, it has been quiet at startup. And since the clatter starts 30-45 seconds after starting (no timing chain rattle at all), I'm guessing that there's something else wrong. Can the fancy timing go haywire temporarily? Those three times it made all the racket, it went on for as long as I left it running. I estimate the first time was probably close to a minute before I shut it off. Immediately after changing the oil and filter, I fired up the engine and watched the oil pressure come up (slight delay with new filter) and noted how quiet everything was. I walked to the back of the truck and opened the garage door to let the exhaust out (windows were open already), and while I was back there, the loud clatter began. I walked all around the front of the truck listening and the racket seemed to be coming from both cylinder heads. The second time was in August, I believe. I had backed out of the garage and was backing up to my porch to unload a new washing machine. Again, at least 30 seconds after starting the engine, the clatter began. This time I started moving the truck all around my driveway and lawn as I listened. I think it had to be 1-2 minutes before I shut it off and it carried on the whole time. The third time was fairly recent in ambient temperature of about 4 degrees after sitting for the day. Was quiet at startup, but while brushing the snow off... yup, loud clatter that continued until I finished with the snow and turned it off. All three times, I restarted the engine and it was very quiet again. I've told a few people that my engine has a very faint knocking sound, but it can only be heard from under the truck. I'm not sure it's correct to call it a knock, it's nothing scary but I've never listened to any other gasoline engine from underneath, either. It doesn't sound bad at all when revved so I have stopped being concerned for now. No ticking whatsoever, though. It makes great power and gets amazing fuel mileage for such a heavy truck.
The oil is still in the engine and unless I buy a new truck, I'll update when I finish the OCI. It'll have at least 10k miles on it when I drain it, and have an entire winter of use behind it.
