Originally Posted By: unDummy
If you're lazy, have no common sense, and don't have mechanical aptitude, then of course its a PITA.
Redline D6 is another option. Supertech DexronVI is if you're a rebel too. Amsoil might have a WS equivalent soon. And WS isn't too hard to find online or at the dealership.
I don't need ramps. My garage floor is level. I refill with a pint to a quart more then I drain out.
My last Toyota: pull drain plug(atf was hot), reinstall drain plug, pull fill plug, fill with equivalent amount plus a quart, take vehicle for ride, pan is similar temp as ATF, measure pan temp with IR, pull overflow plug, let excess drain out, reinstall overflow plug and be done. Also, haven't had any need to replace plug washers(use a torque wrench and most will last forever). Never had a plug leak either. Takes less then 30 minutes every time.
Dipstick requires ATF also to be at correct temp. Temp is often overlooked and is why many people with dipsticks have inaccurate ATF level. We call that user error. Many dipsticks have weird angular bends to them making them difficult to insert and some sticks pull ATF up into the tube so you get only 1 good reading. Easy to fill thru tube but requires extractor or 'loose' drainplug to drain when overfilled. And most ATF tubes fill slowly.
When it comes to accuracy, ATF temp is critical. This might be why some transmissions do not give braindead owners a dipstick to use. Automakers are trying to prevent owner errors. The removal of the dipstick isn't to save money. Its to prevent owner incompetence. Too many wannabee backyard hacks out there.
I have always respected your opinion re: ATF fluids and general transmission maintenance. However,your comments here are a bit over the top. PUH-lease, the ONLY reason for the dipstick-less transmissions is to boost dealership revenue. Sure, there are some clueless people out there. DIY "hacks" on this site are not in that category. Good for you that your truck is high enough to get under to do your quick and dirty procedure of overfill and then drain off the excess. How about doing that on a corolla/matrix/vibe? Suddenly, not so simple. It is stupid to not have a transmission dipstick. You remain correct re: checking at correct temps as always.
