C Carzzz Joined Jan 26, 2008 Messages 424 Location Toronto, ON, Canada Dec 22, 2008 #1 I put slightly over 13,000km on this EaO for 9 months and i notice the filter is all oil up/dripped a few drop on the driveway. Should i replace it?
C Colt45ws Joined Aug 15, 2006 Messages 10,060 Location Central Washington Dec 22, 2008 #2 Did you check to see if it was loose?
R rg200amp Joined Feb 10, 2008 Messages 3,130 Location Phila,PA Dec 22, 2008 #3 If not loose, the gasket has more than likely been compromised with either dirt/grime or when being made, there was a issue with the gasket on the assembly line. I would change it pronto if it is indeed tight and not loose.
