Duramax OCI question
Fort Worth, Texas
My '06 Duramax has 293,000 miles, EGR blocked, PCV intact, M1-303 filter. Have ran Delvac 1300 15w/40 since new on a 7,500 OCI. used oil analysis came back great at 200,000 miles, Have not had a used oil analysis done since.
Had 3 gallons left of the Delvac, Went shopping to stock up. Autozone is running a special on Mobil 1 Turbo Diesel Truck 5w/40 for $12.99 a gallon, Which is cheaper than the stock of Delvac I bought a couple years ago. Bought 24 gallons of Mobil 1 Turbo Diesel Truck so far.
The question is...What OCI should I use now without used oil analysis? I can change my OLM with HP-Tuners.
At least as far as what you were running with Delvac 1300. You probably could have been going much farther. Duramax's are famous for being easy on the oil.
Hopefully DNewton will chime in. He has an extensive database on Duramax oil analyses.
To be honest, none of us can really tell you exactly how far to run the OCI; only a used oil analysis can do that. And a used oil analysis every 100k miles really isn't much to hang one's hat on ... I can tell you that the stock OLM is generally conservative, and often will show a 10-12k mile OCI under the right conditions. Presuming the engine is in good shape (no significant contaminant intrusion) then 10k miles would be the absolute minimum I'd consider. Given your blocked EGR, 15k miles would not be unreasonable, but a used oil analysis would be a good idea to confirm it.
24 gallons of Mobil 1 Turbo Diesel Truck? Geezzzz ... Get one more gallon and you'll have enough for 10 OCIs. Then that would likely cover the next 100k miles.
Love those LBZs!
morepwr, have you done any used oil analysis on your LB7? They're a good way to check the health of the LB7 injectors which have a known weakness. If you have, did they ever show fuel dilution?
Just Curious...
Rob
Just Curious...
Rob
Rob,
I havent done a used oil analysis in a while. The injectors have been replaced and I have a lift pump with extra filtering on the fuel system now. It seems to be very happy but I plan on doing another used oil analysis once I get farther into this latest oil.
Thanks dnewton3.
Just used the last of the Delvac, I guess I will have a used oil analysis done after a 7,500 mile run & report back the results.
Now that I've altered the OLM, It's just a miles counter, Not that mine ever acted like an "algorithm based monitor" when it was stock, 10K every time.
